Salt in fuel tank
Old 07-18-2008, 07:12 AM
natem91's Avatar
Default Salt in fuel tank
Has anyone ever had someone to this terrible act of putting salt in the gas tank. I only drove it about 6 miles until he made me aware that he did something to my car in which i found this. Does anyone know the effects it will have? 2001 Camaro SS
Old 07-18-2008, 07:53 AM
fastvet's Avatar
Take out the gas tank and clean the **** out of it. The salt will mess up the cylinder walls. not to mention clog up a bunch of stuff. Thats a prank that bunch of young kids used to do back in the day. I didnt think they were still doing that. Sorry about your expirience.
Old 07-18-2008, 08:13 AM
speedracer5532's Avatar
Are you sure the salt can mess up the cylinder walls? I talked to a very knowledgeable engine builder and he didn't think the salt would mess things up like sugar would. I was thinking at least drop the tank, clean it very good, replace the fuel filter, and then unhook the fuel line at the fuel rails and flush the fuel line out. Not sure if the injectors would need to be pulled.
Old 07-18-2008, 08:23 AM
vettenuts's Avatar
Pump the tank out. How much did he put in? A teaspoon vs. a quart is a big difference.
Old 07-18-2008, 08:25 AM
natem91's Avatar
More than a teaspoon, salt laying around the flap, I stuck my finger in thru the flap and it was pretty thick.
Old 07-18-2008, 08:27 AM
djfargot's Avatar
dude if someone you know did that to you, i would say its time for an **** beating for real.
Old 07-18-2008, 08:49 AM
fastvet's Avatar
Old 07-18-2008, 09:03 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
A couple things.
I'm not really sure the soluability index for salt in gasoline, but I'm sure it's somewhat soluable depending on concentration. Anything that didn't get dissolved will be trapped by the fuel filter.
Start by disconnecting and removing the fuel filter, let the tank empty, flush the tank with methanol or more gasoline to completely flush it.
Next, when you recconect the gas tank, disconnect the fuel line going into the injector rail and do a couple key-on, key-off routines to push the clean gas to the fuel rail. Let the fuel rail empty as well.
Once you do all of this you should be okay.
If you want to pull a prank on someone that isn't destructive, but merely embarrasing, put a quart of oil in their gas tank. It'll smoke like a chimney but won't really hurt the motor. You'll kill mosquitoes for miles though.
Old 07-18-2008, 09:09 AM
So you don't think the injectors need to be pulled and cleaned or changed?
Old 07-18-2008, 09:11 AM
beerwhiskeyjoe's Avatar
+1 for taking the tank down to be safe, clean the hell out of everything. Better safe than sorry.
I dont know if you know this dude, but I'd be getting law enforcement involved with this.
Old 07-18-2008, 09:28 AM
Bumpin' Yota's Avatar
What effect would it have?
The person who did it would magically dissapear never to be seen from again.
Old 07-18-2008, 09:36 AM
natem91's Avatar
Man you all are making me laugh and making this situation a little easier for me to swallow today.. I am really appreciating all the advice... trust me I would like for him to dissappear but tortured first.... DON'T Mess with a Camaro, Let alone a CHICKS CAMARO...LOL....
Old 07-18-2008, 09:40 AM
bczee's Avatar
To be safe, I would Flush the Fuel tank, lines, fuel rail and change the fuel filter. Run some good grade of Gas (Chevron w/Techron). Might also try some other additives to clean the system and injectors. (Lucas or Seaform)
Injectors or not a servicable unit. (unless you have the equipement that the FI service centers have). Running the additives will help.
I don't think anything is damaged. Just your time and pocket book.
Old 07-18-2008, 09:42 AM
fastvet's Avatar
THAT IS THE FUNNIEST **** EVER! I HAD NEVER HEARD OF THAT!!!
Old 07-18-2008, 09:49 AM
redemn93's Avatar
that oil trick would be totaly awesome. i think i know who i am doing that too.
Old 07-18-2008, 10:22 AM
UNDER PRESSURE MOD
I'm glad I could help. And this is why my gas tanks have locks on them.
Old 07-18-2008, 01:26 PM
NemeSS's Avatar
gas tank cap with lock should be the first mod imo
Old 07-19-2008, 05:56 PM
magius231's Avatar
the destructiveness of various solids in your engine has been pretty overrated for quite a while now.. Sugar actually won't destroy your car or lock up your engine or gunk it all to hell. Salt however is corrosive, so if you do leave it in the tank it could seriously accelerate the rusting process of any metals it comes into contact with. Flush the tank, replace the fuel filter, put a good tank of gas in it and you should be fine. I would make sure to drive it a good bit afterward to flush the fuel lines out.
Oh, and buy a gun
Old 07-19-2008, 06:41 PM
OUTLAWZ RACING's Avatar
Dam that sucks. A good way to get him back is to put GEAR OIL in his gas! I seen the affects of that ****. Can you say desel Mustang! and that **** really stinks. FYI the mustang owner is my buddy his girl friend did it!
Old 07-19-2008, 06:43 PM
Just a thought dont ls1 gas tanks have that little ball in there. Its suppose to be one way to prevent the theft of gas. Who ever did it just cause you a small problem.
Quick Reply: Salt in fuel tank
