Higher oil pressure than usual
Old 07-18-2008, 03:47 PM
T/AWS666's Avatar
Default Higher oil pressure than usual
After changing my oil i noticed my car idles at 60psi instead of 40psi and is higher when acclerating than it used to be. After driving it for a little it will come down some. I checked the dipstick and its a little above the line but i wouldnt call it overfilled.
I have heard that fresh oil raises the pressure buti'm not sure if this is true?
Any ideas why the sudden change?
Old 07-18-2008, 04:40 PM
T/AWS666's Avatar
what do you guys think it could be?
Old 07-18-2008, 05:00 PM
veee8's Avatar
Did you go from 5w30 to 10w40 or 20w50? What filter was on it, and which one is on it now?
Old 07-18-2008, 06:07 PM
flynlow3's Avatar
I would guess you are using a different volocity of oil or a different filter.
Old 07-18-2008, 06:47 PM
T/AWS666's Avatar
5w-30 and ac delco filter before and after. So i guess that rules that out
Old 07-18-2008, 09:23 PM
JFM-jr's Avatar
Waiting for somebody to flame the above . . .
Old 07-18-2008, 10:27 PM
98RedBird's Avatar
I'm going to hope it was a misspelling. Anyways, maybe you used a thicker oil?
Old 07-18-2008, 11:42 PM
T/AWS666's Avatar
same brand and weight as before. I'm really not sure why this happened but it was right after i changed the oil so it has to be something to do with it i would think? anyone experience this before?
