Ok serious cam question and suggestions needed
Old 07-18-2008, 10:40 PM
AustinYukon's Avatar
Default Ok serious cam question and suggestions needed
'03 LS1
Stock shortblock
FAST 92/92 Setup
FAST 36# Injectors
TSP Stage 1 LS6 Heads or something close to those
EWP (not yet purchased)
UD Pulley (not yet purchased)
Longtubes or a midlength (whatever I can find to fit my '56)
true 3" Exhaust
Built 4L60
Currie 9" with probably a 4.10 R&P
I LOVE the Lope and top end power of the MS4 but was wanting something that comes on a little earlier and continues up top. This will be a show and weekend driver car so I REALLY don't like the idea of having to replace the valve springs more than I have to and I figured the MS4 would require a spring change more commonly than I prefer.
I was looking at the Trex but am concerned about PTV clearance. Instead of the specs of the Trex ()
I was thinking about going with something around a 23X/23X with a lift around that of the Trex, maybe a little more and would prefer a 109 or 110 LSA.
MS4 - Magic Stick V.4 239/242, .649"/.609" Camshaft With Your Choice of Lobe Seperation (111 LSA Standard)
Trex - 243.46/249.61 .609/.617 on a 109.31
Are there any out of the box cams that you guys suggest? I know most will suggest a custom grind and that's fine but I was fishing for some suggestions before I go that route.
Dan
Old 07-20-2008, 01:54 AM
Anyone?
Old 07-20-2008, 02:05 AM
99mongooSS's Avatar
um...the spring change with the trex will be around the same time as the ms4 and the trex has a slightly higher powerband.
Old 07-20-2008, 12:25 PM
JPH
JPH's Avatar
Old 07-29-2008, 10:40 AM
Bump. Will edit in a minute
Old 07-29-2008, 10:45 AM
s346k's Avatar
www.texas-speed.com has a custom cam creator. i would use that with this cam:
230/230 on a 111+2 lsa xer lobe. should lope alright and supply great power down low as well as higher in the band.
Old 07-29-2008, 10:59 AM
TXZ28LS1's Avatar
between those 2 i would say the TREX..
but why not look into vengeance racing's VINDICATOR cam..that cam has been making sick power.
Old 07-29-2008, 11:19 AM
Who do you guys suggest I call about a custom grind? any preferences?
EDIT: Someone I can call that is willing to talk to me about overall specs etc. I am NEW to LSX motors and pretty much motor internals in general. I just called TSP and the dude I talked to didn't seem too excited about answering basic questions I had.
Old 07-29-2008, 11:44 AM
2xLS1's Avatar
http://guerragroup.com/camshaft_help.htm
Old 07-29-2008, 01:48 PM
blown03mustang's Avatar
i run the torquer 232/234 on 112 lsa.....plenty of power down low and it doesnt fail to pull up top! good street manors and minimal buckin and surging
you might also check into the torquer 3?
