harland sharp roller rockers dont work well
I tried putting on my harland sharp roller rockers while installing my headers and ls6 intake awaiting winter to do my heads/cam swap but the 1st couple rockers stopped turnign at 1and 1/4 turns and the back rockers kept turning closer to 2 turns I know I need shims for them but why would 1 cylinder need shims while others do not? imperfection in the stock heads maybe??
thanks
thanks
You dont have to have the cylinders at TDC to tighten them!
All you have to do is start the rightside a little then do the left and right and so on. So both sides can get tightened evenly. Then once both bolts are a little tight you torque them down to 22ft lbs. Period!
Goodluck on your install bro!
