LS6 install wow!
LS6 install wow!
I did the swap and I said hey let me clean those heads/int valves. So I had some BG intake cleaners and melted the buildup. So I used a good amt on each intake, cleaned up like new! then I said !@#$ hydrolock! So I pulled the plugs where the valves were open and got the stuff out... So got my brand new intake (not used) bolted on with my OPS and wow! Exhaust sounds different and pulls so much more. Don't know if the head cleaning and intake did it but I could see the 185k of junk on those heads. But with that new OPS and an oil flush the pres is 60 cold, 45 hot idle with syn 10/40...
I think the translation is:
"I recently changed to an LS6 Intake manifold. I also used some chemicals to clean the build up off of my intake and exhaust valves. Concerned about the issue hydro locking I removed my spark plugs to drain the fluid. After installing my new intake manifold I was pleased as punch with the results."
I think there was something in there about me being a badass too but I will ignore his accolades to be professional.
"I was gonna write on Ls1tech.com, but I got high. I was goin make scenes on a thread, but then I got high. Now everyone’s like WTF and I now why... cause I got high cause I got high cause I got high."
