Looking for the best of the best heads
I heard TFS was having trouble with port allignment on their castings. I've heard All Pro does a good head. I heard RHS is good but there's power left on the table with them. I've talked to people who use AFR and like them. They were on the fastest H/C car as well (9.90). I've heard some REALLY good things about a "Thanks 4 Playing" 243 casting with the port done by Joe Mendelis, and valve job done by Bret Bauer. These are the ones currently on my "get" list. A bit expensive, but you get what you pay for! Does anyone have any info on Futral heads done by Larry Meaux?
I see you have ported 243 on your car but I dont know if there hand ported or CNC'd by who and what all they have done to them and what kind of gains they gave you on the dyno or the street or track performance you got. I have stock unported 243 on my car and I really like the Trick Flow heads and when I will buy a set of heads I getting them off of Vengence Racing and (they are a sponsor on here) because on there website they say there CNC ported and from what Ive seen in person and on the dyno there the best out there but they are $2395.00 a set and everyone Ive talk to say you have to have aftermarket rockers which I have been wanting anyway but this is just my opinion and hope this gives you a option. Good Luck
I do not consider Vengence TFS heads in the top 5, much less the best out. Not to be mean or anything. That seems pretty cheap for the "best heads available". I'd like to see what the numbers are at .700-.750 lift.
The heads on the car are what I could afford back when I bought them years ago. Now I'm ready to make some real power with stock cubes. I'm going solid roller so I need heads that will not stall out at high lift.
i dont think hes looking for suggestions on what else he should do, just on the best heads... im also curious who would be the best to send them to get ported. best as in best quality with price not being a factor
I have talked to Bret, he doesn't recommend the Darts for a stock bore. He recommends the 243's that Joe Mendelis designed the port for. They are a bit pricey, but I am willing to spend when the product delivers. These heads have been on championship cars, so I am going with his heads/cam package, prob solid roller, and possibly setting up a vic jr intake as well. Just wanted to make a post and see if there were others I have not considered.
CARTEK Racing
Greg Good does awesome stuff,
But for my experience I cant say enough about CARTEK Heads.
After all, 10.32 @ 132+ on 243 heads driving it to and from the track, cant be that bad.
Yep, his Darts are for for bigger bores. For a 346 your looking at either a AFR, Ported OEM, since your bashing TFS I wont mention them, maybe ET?
I dont think All Pro are for smaller bores but maybe someone makes a version for the 346?
Good luck in your head hunt, but since you have eliminated what should have been your first choice, I would suggest the ETP's then the AFR's for what you are looking for on a 346. Talk to both manufacturers about their solid roller setups and see what they suggest.
I just hope you don't base your judgements of what is best of the best, on the most expensive must be better philosophy!
The TFS heads might be great, but I don't know who Vengeance had design the port they CNC so I am not considering them. I hear the newer CNC version ET is releasing on their TFS heads is supposed to be really good, but I haven't seen any results on those. I know the guy holding the 9.90 stock cube H/C record was using AFR's, and I don't see any TFS results better than mid 10's.
1 Post
