How would the motor run if the cam was a tooth off?
14 Second Truck Club
My truck makes good power (Mods in sig) but on the dyno, it only makes 394/408 locked in 3rd gear. The power curve is good but takes a dump right about 5600 rpms. It should pull to at least 6000-6200 with the cam and ported 90/90 set-up. Could it be a tooth off? I would think it would idle and drive like crap if that was the case. I know nothing about installing or checking cams or I'd check it myself. I've got the hex-adjust timing chain and the engine builder told me at first he advanced it 4*, I then told him it already had a 4* advance ground in it. He messed with it before loading it up in the back of my truck and said that he fixed it to where it was straight up. I know the patriot heads could be upgraded to something like TFS or AFRs and make a lot more power, but they shouldn't be holding me back that much. Right?
Here is a link to the other post a while back with my dyno chart:
https://ls1tech.com/forums/dynamometer-results-comparisons/826427-what-do-head-problems-look-like-dyno.html
I'd say the cam is to far advanced. It could still drive fine being off a tooth as long as there is no piston to valve contact. Does it idle steady with a smooth lope or is it choppy and uneven sounding? If the cam is advanced to much the exhaust valves will open early and make it sound like a blown alcohol motor idling. Is it possible for you to get an idle video and post it up?
I'm gonna try and get it checked by futral as soon as I get some extra cash. I can't post a video yet, don't have internet at the house and then I have to figure out how to download it and all that. It doesn't idle all that bad. The cats & mufflers eat up a bunch of the lope. It idles about the same as my old cammed 5.3.
LS1 Tech Administrator
I'd wager the cam is in at 106 intake centerline and not 110 as it should be. Probably not a bad powerband for a truck, but you're still not getting best use of the combo the way it sits.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Hopefully that'll be good for a low or mid 11 second street truck.
If the cam is installed at the 106 intake centerline, how much power would I gain at the 110 intake centerline? How much would it move the powerband up? Thanks.
