polishing aftermarket heads worth the $
Old 07-29-2008, 08:40 PM
colews6's Avatar
Default polishing aftermarket heads worth the $
got a set of prc 2.5 5.3 heads and noticed some rough cast spots in the runners and chambers. i figure this is with all factory cast heads the prc, patriot, livernois etc. so should i get them polished? and will it help get the full potential out of the heads.
Old 07-29-2008, 10:09 PM
Paint_It_Black's Avatar
No, you don't want a mirror finish in the ports. Combustion chamber, yes, ports, no.. leave the CNC track lines alone.
These are not "as-cast" heads, they are ported factory castings.
Old 07-29-2008, 10:13 PM
88ls1blazer's Avatar
I wouldn't touch the chamber personally even. What you might gain in flow/efficiency you will lose in loss of compression
Old 07-29-2008, 10:58 PM
AaronR's Avatar
They dont need to be polished just to make them smooth.However,there is certainly room for improvement in the hands of a good porter.
Old 07-30-2008, 02:52 PM
colews6's Avatar
well i figure i wouldn't get a mirror finish on the intake, i still want the fuel to mix good before entering the cylinder, but see the rough cast spots smoothed down because it is rough. the exhaust ports and combustion chambers i would like a mirror finish so there's less chance of carbon build up and better exhaust flow.
Old 07-31-2008, 10:06 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
If you mess with the heads you have to be really careful. It's really easy to accidentally mess the valve job or the cylinder head itself up & not even realize it. We use a very small step over on the new PRC heads so hand polishing the ports will make little to no difference IMHO.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
