Cam bearings or all bearings
I am doing a H/C sap with the engine still in my T/A. I pulled the heads first and everything looks fine in the cyliders. When I pulled the cam the journals have deep grooves in them. The cam bearings are obviously shot. At this point I am thinking it would be a good idea to pull the motor and have a look at the crank and rod bearings. Would this be a good idea? How often do cam bearings wear out? Anything else I need to look for? This is an original 98 motor with 97,xxx mi.
With that many miles on the motor, go ahead and remove the engine and do a nice overhaul. Dont go cheap on it either. Go ahead and replace the valvetrain parts like lifters and what goes in with the cam. Definitely have everything checked and prob should get it balanced to while its all out. If you can go ahead and change out your piston rings and all that good stuff.
Give Glen Sheppard a call, he did all of my machine work. PM me for his number if you live close to Bessemer/McCalla area.
