Heads will be off of the car for 3-4 weeks, what .....
Heads will be off of the car for 3-4 weeks, what precautions need to be taken to be sure nothing happens to my shortblock. The car wil be parked in a garage, away from the elements, will keeping a rag over it be enough, or should I tape plastic over it? Also, should I wipe down the cylinders w/ WD40 or equivalent? Any other tips would be appreciated, thanks, Shawn
Re: Heads will be off of the car for 3-4 weeks, what .....
I'm not sure WD-40 would be a good thing to use. WD-40 displaces water and the water has to go somewhere else...like maybe into other areas you don't want it. Friend of mine that's a maintance person says WD-40 applied at the wrong time in the wrong enviroment can actually cause more problems than it prevents. While aluminum won't rust, stripping the water aways from other metals with WD-40 can actually speed oxidation by increasing the metals exposure to air ie it rusts quicker, or so he says.
Maybe oil would be better to wipe the cylinders down with? Perhaps someone that knows can respond.
I can shift faster than you.
Just use some motor oil in the cylinder walls and place some large towels over the motor. Just wipe the old oil off (to be sure no dirt, lint,etc stuck to the oil) and apply a very thin coat of fresh oil on the cyl walls before putting the heads back on.
