LS2 heads/ LS6 cam/ Pushrods
I've searched...seen lots of posts saying with LS6 heads/cam you would need slightly longer 7.425 pushrods.... but what about with LS2 heads?
pushrods
With LS6 heads and cam you would use stock 7.4 pushrods the LS6 cam has a different base circle due to its lift and LS6 have shorter valves to allow for this. LS2 have standard length valves and supposedly need the 7.425 longer pushrods - I have heard you can still use 7.4" and still be OK but i cannot verify this. I think that anything other than stock needs to be checked to verify correct length.
