Slight oil leak.
If the leak started AFTER your oil pump install, it is the oil pan gasket. You should drop the pan again and check the gasket to make sure it still has some "spring". If the gasket is still in good shape, put a small dab of sealant on the little waffle pads at each corner, then reinstall and torque properly.
Shane
Shane
