C5R block Vs. Darton wet sleeves
Does the Darton-sleeved block have any advantages over the very pricie GM C5R block?
Any chance the prices will decline?
Re: C5R block Vs. Darton wet sleeves
Yes. The Darton wet system replaces all the aluminum material surrounding the piston bores. They are also integrated with each other to prevent shifting. I believe they are ductile iron. Not sure on that though.
1 Post
The Darton sleeves are stronger, and much cheaper.
7 Second Club
Location: Grove City Ohio/Port Washington L.I sometimes
Only advantage of darton sleeved block is affordabilty(salesman speak).I doubt if the C5R will come down in price anytime soon.I would say it's more likely to go up in price.I have complete confidence in my ARE updated resleeved block.
Leo:
When you say the Darton is more apt to leak are you referring to water jacket leaks, oil leaks, or compression leaks....?
In my opinion there isn't enough of the NEW Darton sleeved blocks out there yet to know their true durability. I have more confidence in ARE's resleeving than anyone else's so far. They too use Darton sleeves but they are custom made only for ARE. I haven't heard of a sleeve problem with an ARE block in probably 2 years and some guys are running ~1000hp with them.
In the early days I heard of problems finding a perfect C5R block, which is scary for the money they sell for, but lately I haven't heard any more bad stories about C5R blocks.
...lots of posts here about dropped dry sleeves ...including the newer work...
...IMO, too much risk - for me
I may just to an all stroker...???
I have to wonder just how many leaky Darton-dropped sleeve motors are really out there.I would have a big cube motor right now if not for the worry on those issues.C5R block not in my budget.
Lets get the C5R block down to $3000 and they would sell a ton of them.Dreaming
7 Second Club
I thought the dropped sleeve problems were limited to dry sleeves made by Darton and others...
Aren;t the wet sleeved Dartons LOCKED so that droped sleeves can;t occur?
the only isue with locked Dartons is price (about $3.5K with a cheap $600 core) right?
the difference in cost between the Darton wet and dry sleeves is not great about $500...
...so, if your inclined to go this route, it seems silly to go dry; right?
I've heard of block problems from all camps including ARE. If I were building a big bore I'd go darton wet or nothing, the C5R is just too expensive.
I called Joe Prince concerning this. I inquired about a 388 all bore and the options for the build. He told me that he build me a forged bottom end (stock crank) with the Darton wet sleeve short block for under $5k- including cam and chain.
I don't see how there would be any other option.
I'm holding my breath and waiting to see if the new 6.0 C6 block will be backwards compatible with GEN III. I heard the internals will work in the new block, but the new block will have the knock sensors mounted on the side of the block and the crank position sensor will be in the front cover. The crank position sensor throws me off though,,,,if it is going to be on the front of the crank I don't see how GENIII cranks will be compatible.
Lingenfelters wet Darton block is $3.5 K. ...add pistons at $500, Rods at 500 and your about 4.5K, cam at 300....
So is the Joe Prince motor a deal?
LS1Tech Co-Founder
C5R is the strongest block, it's a production block with thicker webbing but they cost $6000.
