Bad Noise, PLZ Listen
Old 08-03-2008, 02:53 PM
tilly's Avatar
Default Bad Noise, PLZ Listen
Hello,
I recently changed the head gaskets, cam, lifters, timing chain, valve springs. I had the heads checked by a machine shop when the installed the valves and its not a pulley.
Sometimes I would here a very loud squel and the car would die, but I can start it again.
http://www.youtube.com/watch?v=V6F8OXQKTaU
THanks for the help
Tilly
Old 08-04-2008, 12:49 AM
tilly's Avatar
I really need help. I am not sure if this would be a rod bearing or a cam bearing. This is not a usualy bent pushrod ticking LS1.
I am runnign hardened pushrods, LS7 lifter, a cam from thunder racing and comp 918s with 1 hour of running time so far.
Old 08-04-2008, 01:01 AM
snake charmer's Avatar
dont sound right . is there a certain area it is coming from ? does it drive ? is the throttle affected any ?
i would just start taking stuff off .
Old 08-04-2008, 01:29 AM
tilly's Avatar
I could drive it, I do not want to wipe out a 400 dollar cam.
Now, if the car is idling and I hear a louder squel, the car will immediately die and I can turn it over by hand but the starter motor is able to break it loose (oddly).
Would that be a cam bearing?
