need help - vibration
Why does my shifter vibrate and the car shakes very bad when I rev it up in Neutral? Also whenever I somewhat lay into it, around 2.5k rpms, the shifter started shaking and vibrating violently. The only thing I can think of it being is a warped clutch. Any other opinions?
Also the car shifts normal, there are no weird noises coming from the shifter area when idling or driving, and there are no weird noises coming from the shifter area when the clutch pedal is pressed in or depressed.
