dart 250cc heads on 408 stroker or AFR 205s on forged 346???
Old 08-07-2008, 03:11 PM
1sick-Z's Avatar
Default dart 250cc heads on 408 stroker or AFR 205s on forged 346???
I have a set of dart 250cc heads fully cncd brand new flow 354 @ 600"lift made for a big bore tho. My question is should I sell those and buy the AFR 205's and just forge my LS1 bottom end rather then going with a new block and everything let me know ??? thanks
Old 08-07-2008, 03:42 PM
1sick-Z's Avatar
I am just torn on what to do I got a great deal on the CNC darts and couldnt pass them up but I really want to keep stock displacement to avoid buying all new block and changing camshafts and everything else that goes with a big bore motor
Old 08-07-2008, 04:37 PM
ThirdGenLS1's Avatar
well i would either keep the darts and do a 408 build, or sell the darts get a nice set of heads and keep the stock short block. No point doing all the work to doing a forged block and everything to stay stock displacment.
Old 08-07-2008, 04:45 PM
CJohnsonZ28's Avatar
If you decide to stay with the stock motor and not go with a 408 I am interested in those heads haha. PM me if you are selling them please
Old 08-07-2008, 04:49 PM
1sick-Z's Avatar
for sure man they are a wicked *** set of heads to but like I said I am still up in the air whether or not to go big I will def let you know tho
Old 08-07-2008, 04:54 PM
Ok thanks alot. They sound like they are awesome heads. Either way you go you cant go wrong. Good luck!
Old 08-07-2008, 04:56 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Just buy an iron block. The only cost difference between building that and a forged 346 is the block and crank. That's about $1000 in used parts. The power difference between the two will be huge. You'd be kicking yourself in the *** down the line if you build the 346.
1sick-Z's Avatar
only reason for wanting to build up my bottom end is because of those cursed 99 LS1 rod bolts so I will just do rods pistons/rings and a hone with all new bearings keeping the stock crank because i beleive it is good for some power but crank block changing the cam again for a 408 will add up as well I just see great stock cube numbers out of the AFR's thats y i wanted to know
Old 08-07-2008, 05:14 PM
1sick-Z's Avatar
very good point if I buy a LS2 I can use the stock crank and aftermarket rods for a 408???? or is there a diff crank I need to buy
Old 08-07-2008, 05:19 PM
you need a 4.03 bore and 4 inch stroke for a 408. Stock ls1 is a 3.98 bore and a 3.622 stroke.
Old 08-07-2008, 06:03 PM
Blackss99's Avatar
First what are your horsepower expectations?
Old 08-07-2008, 06:11 PM
1sick-Z's Avatar
500+whp just let me know what internals I need after a LS2 block
Old 08-07-2008, 06:14 PM
500+ you need a stroked block for that, so a 402 ls2 or a 408 iron block is what you are looking for.
Old 08-07-2008, 06:26 PM
1sick-Z's Avatar
so that would mean I need a complete rotating assembly crank rods pistons??? would it be cheaper to buy an assembled block or build my own ???
Old 08-07-2008, 06:29 PM
meh its close, if you have all the tools and knowlege then you can prolly build it cheaper. But i would say your best bet is to get a built short block from eric at HKE.
Old 08-07-2008, 06:33 PM
beardWS6's Avatar
ET 245`s and a iron 408 here. Love the power and TRQ. Mine is also a A4! So I make awsome power!!
Erik built my motor. 408 all the way!!
Old 08-07-2008, 08:03 PM
Randy WS6's Avatar
I run Dart PRO1 255cc fully cnc'ed on my LS2 418cid. Very nice set of heads
Old 08-07-2008, 09:43 PM
SOMbitch's Avatar
Sorry to hijack but I have been on Darts website and don't understand why the don't offer cnc'ed 205's but do the 225's and up???? Furthermore I know Bret Bauer works near miracles on the 225's and bigger but why can't they be replicated on the CNC offered heads??? Just wondering cause I would love to have some BB heads but have to go budget as seen in sig not that I am complaining.
Old 08-08-2008, 06:01 PM
1sick-Z's Avatar
another question how big could I go on the LSX block ???
Quick Reply: dart 250cc heads on 408 stroker or AFR 205s on forged 346???
