Proudly Introducing Tick Performance's Flagship LSx Camshaft: The Polluter
Check out our thread in the Dyno section for all the details:
https://ls1tech.com/forums/dynamometer-results-comparisons/969227-proudly-introducing-tick-performance-s-flagship-lsx-camshaft-polluter.html
Yea, that promo was pretty sweet. One other question I have, this cam on the 112 works on the stock heads...have you tried other heads, such as 2.5 5.3 heads, up to AFR 205 and 225's? Good cam for other combinations? Or the 110 lsa for larger heads, like the AFR or TEA's.
LS1TECH Sponsor
The PTV clearance is borderline of what I would consider acceptable for a hydrolic roller. It does have slightly more PTV clearance than a few other larger camshafts out however. It should work well with 2.5 5.3 heads, cnc'd LS6 heads, etc but with any milling, thiner gaskets, or larger valves ptv only becomes closer and some combos will require notching.
We have a car in the shop right now scheduled for the cam on a 110 LSA along with the TFS 215's milled to 58cc's. The pistons were notched already from a previous cam/head combo so hopefully everything will work out. The car is an a4 so don't expect record breaking dyno numbers however. I'll post the results as soon as we get them.
Guys,
I ordered this cam this past Friday. If you have any interest in this cam, definately call them up and talk to Joey. My polluter is going in a week from this saturday. I will have dyno result for you guys that following week.
-Brian
-Brian
