biggest CI before AFR 205s choke
Old 08-19-2008, 06:42 PM
landonew's Avatar
Default biggest CI before AFR 205s choke
If I was looking to build a forged shortblock (w/ intent to spray 200-300 N2O), how big could i go before running out of head. At some point the AFR205s will begin to choke it out at high RPM. I was thinking 402/403 ls2, but would rather bump it up to a 416/418 ls3. Would the ls3 like the smaller heads?
Old 08-19-2008, 06:56 PM
Super Speed's Avatar
From what I understand its better to sell them if you plan on going bigger cubes...
You leave ALOT on the table with such a small runner!
Old 08-19-2008, 07:04 PM
LS1 Tech Administrator
Patrick G's Avatar
You're more hp limited than cubic inch limited. The port can only flow so much air. Some people have made in the 525rwhp range with AFR 205s, but that seems to be around the limit (naturally aspirated of course). That means you could make that much power with a 346 or a 440. The biggest difference is that the smaller motors will need more rpm to make the same power and they'll have lots less torque than the strokers. Don't expect to make more than around 525rwhp regardless of how big your shortblock is (unless you run solid roller, add a sheet metal intake, and run 8000 rpm).
Nitrous is a completely different animal and the AFR 205s have an outstanding exhaust port capable of supporting over 800 rwhp on the spray. The question is, is the rest of your combo set up to evacuate that kind of exhaust volume?
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 08-19-2008, 07:20 PM
landonew's Avatar
I believe so. I have kooks LT 1&7/8" headers and 3" TD over the axle.
Patrick, would you suggest that i upgrade my heads when going to a 418? Aside from the cost, what benifits (if any) would i derive from sticking with the smaller cubes?
Old 08-19-2008, 09:18 PM
Patrick G's Avatar
If you stick with the AFR 205s, at least have the combustion chamber opened up to 4" bore. This will enhance your low lift airflow by unshrouding the valves more and giving them a better funnel. If you're going to run a 300 shot, you may want to port the exhaust a little more too.
Your cam timing, especially on the exhaust lobe better be up to evacuating 800 rwhp. You'll want to open the exhaust valve much earlier than you would NA.
__________________
Old 08-20-2008, 12:40 PM
landonew's Avatar
Assuming I take your advice and send the heads to tony for freshening up, and have you custom spec the cam..... How much am i leaving on the table by not upgrading to the AFR 225/235s?
I think that i could maybe sell my heads and buy the 235s for around $1000 out the door all said and done. The AFRs keep their value, but at the end of the day they are still slightly used.
Old 08-20-2008, 12:52 PM
Patrick G's Avatar
Talk to Tony. For the price difference of upgrading to AFR 225s, you may be able to have him massage the 205s to give you the airflow your stroker needs.
__________________
