reluctor ring
Old 08-21-2008, 09:59 AM
never2low's Avatar
Default reluctor ring
I just bought a 01 Z06 motor for my 00 Trans Am. I think to T/As and vettes had different reluctor wheels on the crank but I may be wrong. If so what doI need to do to make the vette one work in the T/A? Thanks
Old 08-21-2008, 11:41 AM
nj02vette's Avatar
No,
They had the same 24x reluctor wheel. I believe it was changed to a 58x in 2005+ Corvette only LS2's.
To get it to work, you'd have to swap oil pans, they were different. You'll also have to delete EGR on your car. Otherwise, I think most everything else will work fine.
I'm sure some more informed expert will chime in here.
Old 08-21-2008, 11:50 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
If the reluctor was your only concern you are in the clear. It is the same reluctor.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 08-21-2008, 01:21 PM
never2low's Avatar
Great thanks guys.
