can i get 500 hp with this heads/cam setup?
Old 08-22-2008, 11:12 AM
wilwhite2kss's Avatar
Default can i get 500 hp with this heads/cam setup?
My goal is to make a 500 hp car and then be done with it, Think i can do it with this setup? I know the heads are capable , but not sure of the cam. Any advise would be appreciated, maybe some possible cam specs. This setup will be tuned. I know alot depends on the tuner, but is it possible, or how far off am i?
tfs 215 heads
Fast 92/ fast 92 tb
harland 1.7 rockers
7.500 pushrods
mellings 18% oil pump
ls2 timing chain
coolant crossover pipe
underdrive pulley
exhaust for now is hooker lt's / y pipe/ slp lm
and finally the cam that is in question which
I think its too small.
228/230 558/ 112 lsa
Old 08-22-2008, 11:18 AM
Frans96SS's Avatar
I doubt with that cam you will get 500rwhp. I did a very similar set up in an auto but with a custom cam from me.
https://ls1tech.com/forums/eastern-members/958908-race-proven-motorsports-tfs-215-rpm-3-cam.html
Old 08-22-2008, 11:26 AM
nahasapeemapetalon's Avatar
Magic stick v.3 cam? 237/242? I havent seen dynos but i have heard some good things. Something to look into. Thats what I would do if I were you or at least a cam in that range. You talking 500rwhp? If so maybe 1-7/8 headers with cutouts and an ewp?
Old 08-22-2008, 11:44 AM
tilly's Avatar
That should get you over 500 crank hp but 500 rwhp probably not. Its hard getting 500 rwhp on a stock bottom end NA unless you run some high compression with a big cam and every bolt on under the sun. If you want 500 rwhp hit it with some laughing gas with your setup.
Old 08-22-2008, 11:59 AM
AzzBustin30th's Avatar
def. get rid of the of the hookers and get kooks or qtps. what are the heads milled down to and what size head gasket are you running?
Old 08-22-2008, 12:10 PM
johnLs1camaro's Avatar
i think the setup your looking at will get you at 450 hp maybe...m6 or a4??
Old 08-22-2008, 12:13 PM
180ls1's Avatar
that setup could get you 450rwhp but with a very nice curve and good usable power. It also would daily drive very nice. But you will have to go bigger if you want 500rwhp.
Old 08-22-2008, 12:35 PM
TXZ28LS1's Avatar
i dont think you will make 500hp.. but i also think maybe 450. you probably should go bigger on the cam to get that. but if u go with a bigger cam u drivability will be pretty rough depending how big you go. but that looks like a good setup for a daily driver though.
Old 08-22-2008, 01:10 PM
mike#9's Avatar
Honestly...not a chance to hit 500 with that setup....and not the best odds to hit 450.
Old 08-22-2008, 01:15 PM
allngn_c5's Avatar
Nice heads choice, but you should consider a much larger cam. I would strongly suggest you look at LG Motorsports and inquire about there G5X3 version II. I have that cam in my car (see sig) and I love it. I like it so much that when I have the $$$$ for my motor swap that is way over due because of lack of $$$$ I will be re using it in the 402. With a good tuner, the g5x3 vII is great. Its all in the tune. My setup made 490 rwhp 445 rwtq
allngn_c5's Avatar
Hopefully the 402 will make a bit more and a lot more torque....
Old 08-22-2008, 01:17 PM
ss.slp.ls1's Avatar
There was a write up posted a while back from a guy who hit 500rwhp on stock cubes. IIRC he used:
ported AFR 225's
ported Fast 90/90
1 7/8 LT headers w/ magnaflow merge collector & cutout.
Big Cam (sorry, don't remember the specs)
Really good tune
Old 08-22-2008, 02:47 PM
WSsick's Avatar
get the 92/92 ported and definately a bigger cam that matches your heads, and 1 7/8 headers will be good for a big ol' cam too.
Old 08-22-2008, 04:54 PM
dyls1's Avatar
ported AFR 225's
ported Fast 90/90
Really good tune
this one?
https://ls1tech.com/forums/generation-iii-internal-engine/732392-recipe-500-rwhp-heads-cam.html
Old 08-22-2008, 04:55 PM
ss.slp.ls1's Avatar
Originally Posted by dyls1
Yep, that's the one.
Old 08-22-2008, 05:15 PM
ss.slp.ls1's Avatar
Default Cliffnotes...
Read the write-up above, it is very very informative!
Here are some cliffnotes:
Ported AFR 205’s milled .060”
AFR 205s with 57cc chamber:
Lift.........200", .300", .400", .500", .550", .600"
Intake.....158,.. 220,.. 264,.. 285,.. 296,.. 300
Exhaust.. 122,.. 178,.. 217,.. 232,.. N/A,.. 241 (with pipe)
Ported Fast 90/90
Flat top pistons with 2cc valve reliefs and .041” head gasket to get a DCR of 11.92:1
Intake closing point of 48* ABDC at .050” gives SCR 8.86:1
Ignition timing @ peak torque is 28* and 30* at peak hp.
235-240* intake/240-244* exhaust
Lift in the .600” range
Comp XE-R lobes
Overlap of 16* at .050”
112 LSA
Upgraded springs: spring height of 1.775” spring pressure of 170 lbs and 450 lbs open
TI retainers
Hollow stem 2.02” intake valves that weight 98 grams
1.6” exhaust valves that weight 97 grams
Yella Terra Ultra-Light rockers (shaft mounted) shimmed to .050”
Comp R hydraulic lifters
Rocker bolts got 3/8 to ½ turn past zero lash
7.4” pushrods
1 3/4” LT headers, dual 3” pipes that merge into a 4” intermediate pipe, flowmaster merge collector; 4” cutout
He also ran a UD pulley and elec WP.
Old 08-22-2008, 05:45 PM
derschmeid's Avatar
grab a cam that loves spray ms3 is a very popular choice and then a 100 shot... weill into the 500s
coolant crossover pipe..all those great items but yet you still list this as a mod...
Old 08-22-2008, 06:16 PM
SOMbitch's Avatar
Vengeance racing is making some 500 rwhp cars with tfs heads.
I bet you will have to flycut or go forged pistons with valve reliefs, milled to 59cc and a good sized cam and a killer exhaust to get there.
Old 08-23-2008, 10:06 AM
9secondsflat's Avatar
i made 532 rwhp BUT with a 383 and every bolt on possible- ati underdrive, meziere, ported fast....read signature...
call Vengeance or ECS both have made 500+ rwhp on 346's
Quick Reply: can i get 500 hp with this heads/cam setup?
