AFR 205 heads on a stock LS6. Any gain?
I put these heads on a LS1 motor with a 220/224 581 114 cam. I gained 30 rwhp. 23 rwtq. I have Kooks headers, CAI, and a LS6 intake. Total 402 rwhp 380rwtq.
After many autocross races and track days it finally let go.
Just had installed a stock LS6 long block. It dynoed at 374 rwhp. 362 rwtq.
My Kooks headers and CAI are on the motor.
If I just add my AFR heads to this new motor what kind of gains should I expect? Should I mill the heads? Thinner head gasket only?
I'm on a tight budget now.
thanks,
Steve
thanks,
Steve
I'd say thinner head gasket, get the static CR up around 11.5:1 if you can, maybe mill the heads a tad, and enjoy the awesome throttle response (tip-in) the AFR's will offer - as well as some very good peak numbers. ENJOY!
thanks,
Steve
thanks,
Steve
Hey guys I was just thinking. It will probably cost around $2k for milling the heads, pushrods, new 8019 springs, tune, etc. and installation. What about just putting in a small cam and leave the heads alone. It would have to pass smog. Do you think the 220/224 581 114 would be a good choice? I had this cam before and with new cats it would pass. I think putting in a cam would cost about the same as the head installation. I do need good power from 3000 rpm and up. Autocross car mainly.
thanks again,
Steve
thanks again,
Steve
thanks again,
Steve
thanks again,
Steve
This thread has everything you need to know https://ls1tech.com/forums/dynamometer-results-comparisons/327229-stock-02-z06-afr-heads-414-rwhp.html
I talked to Tony and he said that I should mill the heads to 63cc. Plus use the thinner head gasket. 8019 springs? On occasion, I would like to rev this motor to 7100rpm. On some autocross tracks it would be nice not to shift into 3rd. I thought it would probably cost around 2k for labor and all the necessary parts.
Steve
Steve
Yes, that will be good for what you are looking for. If you decide to go the head milling route instead of the cam, there's also the option of adding 1.8 roller rockers to increase the valve lift of your stock cam.
