Making a GMPP Hot-Chili-cam
I have been pretty set on picking up a new GM hotcam. It does everything I want and sounds perfect for my application.
Can't talk me outta it
Specs are:
219/228 .525/.525 112LSA
The only thing is the fact that lobe technology has come a LONG way since then. And .525 lift, while being nice and easy on the valvetrain, is considered rather soft today, therefore, I was going to add some 1.8 RR as well and bump the lift up around .560
That got me thinking.... ..... what if I could get spec the original Hotcam with new lobe technology
What would happen if I specced a:
218, .605" XFI intake
228, .588" XER exhaust
111LSA
ICL - Don't know
Would a Hot-Chili-cam be a good thing?
Thought, opinons, insights and comments required
Also if you think I've completely lost my mind
Specs are:
111LSA
ICL - Don't know
I think you defeated the main reason people buy the hot and asa cam. that being they can run LS6 springs that cost $52. The way you specced it you would need atleast 918s and maybe duals
I think a set of 918s work well with XFI lobes so it should be sweet there.
Still a hell of a lot cheaper than 1.8:1 RR thats for sure
ASA Cam on XFI/XER lobes?
Not for my application but imagine how wicked THAT would be!!!
Just need to convince TSP to try it now
Post #52:
https://ls1tech.com/forums/generation-iii-internal-engine/973317-tsp-goes-back-engine-dyno-stock-346-ls1.html
Post #52:
100%.... 918 springs would be used with it
The real questions are:
- Would it work?
- Would it be worth it?
- Would it make gains (>20rwhp+) over the Original GM HotCam
- Are those specs the right ones to update this cam with 2008 technology
- Would it work?
Ummmmmmmmmmm.......... Huh?
From Texas-Speed website:
Comp Cams LS1 Custom-Grind Camshaft; Pic Your Own Specs! $369.99
TSP Custom 224/224, .566"/.566" Camshaft With Your Choice of Lobe Seperation. $369.99
Or I can take your recommendation:
TR224/224-112 Thunder Racing Custom Camshaft $389.99
dont be a dick when people are helping you, and when they give you good advice. I never said only get that cam i said just look at that one. But i promise that tr224 is worth the extra $20 and it will **** on the hotchili cam all across the board. I also thing the 224 on .581 lift is a bettter cam then then tr cam on .566
That is totally the case. the cam is unproven you do not know nearly enough about a cam to just throw parts about two cams to gether and hope it goes well. And you can get used but in good shape 224's for $200 or get a fresh grind hotcam for $100 so you are really not saving money. There are also other 224s that you can get brand new $250, I never said just ger the tr one i was just using it as an example please re read what i said.
how the f is he going to gain 20-30hp just from a change in cam lobes? have you not noticed the asa cam is consistently putting down 385-395whp...so you're saying that changing lobes will put you at or near 400whp? eehhh i'm not so sure. the cams work excellent as they are AND can utilize ls6 springs (as mentioned). i wouldn't put the additional abuse on the valvetrain for such a subjective gain in hp. i'd spend the $2-300 elsewhere, like an udp and tires or something.
