ls1 strokers
Old 09-01-2003, 11:23 PM
dis3as3d's Avatar
Default ls1 strokers
Im doin a little research on ls1 strokers plz post your numbers, displacement, kit you used etc. TIA
Old 09-01-2003, 11:53 PM
LS1Tech Co-Founder
Nine Ball's Avatar
Default Re: ls1 strokers
MTI 382ci All-Bore, 221/221 T1 cam, 455 rwhp, 440 ft-lbs SAE corrected Dynojet
MTI 434ci, 244/244 S1 cam, 525 rwhp, 520 ft-lbs SAE corrected Dynojet
Both were FUN setups. The 382ci was much better for daily-driving, the 434ci was a bit too insane for daily driving, especially since I couldn't floor it until 3rd gear.
Tony
Old 09-02-2003, 12:40 AM
2001CamaroGuy's Avatar
I'm thinking of doing a 388 all bore within the next year (4.125 bore w/ stock crank)....
would my current TR 224/224 112LSA be too small for that engine? I noticed Nine Ball made 455rwhp with a 221 durration....
I have a 234/230 on a 112LSA that was too big (p-to-v) for my 346 (milled heads)...would that be better?
Old 09-02-2003, 10:22 AM
dis3as3d's Avatar
Is anyone running the lunati 382 stroker kit with 3.9" bore and a 4" stroke?
Old 09-03-2003, 11:38 AM
WA 2 FST's Avatar
Tony
Tony,
Can you tell me where these two combos make peak HP/TQ?
Thanks!
Old 09-03-2003, 11:42 AM
XFACTOR's Avatar
Im going to the MTI 396 setup after the first of the year!!
Old 09-03-2003, 03:13 PM
LS1Tech Co-Founder
Nine Ball's Avatar
Even better, here are three MTI dyno graphs overlayed on eachother for comparison. This will illustrate why cubes are king.
Old 09-03-2003, 05:12 PM
99 Black Bird T/A's Avatar
Received 1,431 Likes on 991 Posts
Tony, 148 dyno runs according to the graph?
Is that a record?
Old 03-22-2004, 10:09 PM
DG Gordon's Avatar
These are all bores right not strokers?
Old 03-22-2004, 10:18 PM
DenzSS's Avatar
4.030 Iron Block
4" Callies Crank
Dyer Rods
Diamond Pistons
Old 03-22-2004, 10:23 PM
770Guy's Avatar
Futral Motorsports 396 stroker here.
504rwhp 481rwtq
