Oh Sh*t Somebody Help!!!
I was checking my EGR on the top of my intake manifold while the car was running and heard a vacumm leak. I loosened the bolt and was messing with it to get it to quiet up. I wasn't thinking and I yanked on it. The EGR gasket got sucked onto the intake and then the motor stalled because of the big vacumm leak. What do I do? Is it still in the intake? Will it get spit out the tail pipes if I start the motor? Please help!!!
You could pull the throttle body and look in the intake with a flashlight. You may see the gasket and be able to pull it out of there. If you don't see anything it has most likely already went into a cylinder. As long as it doesn't hold a valve open causing piston to valve contact it will burn and come out the exhaust causing no damage. A friend of mine started his car with a shop rag in the EGR hole and it came out the exhaust in flaming chunks. If that happened and his car is still running fine I'm sure a little o-ring will be alright.
