Patriot LS6 or 5.3 heads?
Wondering if someone could give a little input on whether I should go with the patriot LS6 2.5 heads or the 5.3 stage 2.5 heads? Mods are as follows...
XER273HR-114 224/230 .581/.592 114lsa
Vig 3200
LS6 Manifold
Hooker 1 3/4" Longtubes
The car is a '98 Trans Am with the stock shortblock and heads currently. Looking to pick up a new set of heads and on a budget. Any input guys?
Vig 3200
LS6 Manifold
In about two weeks Ill have a set of 59cc Patriot Stage 2 ls6's with 2.055/ 1.57 valves for sale for around $800.00 They were bought new in November and installed Dec. 08 and being takin off right now. Had a cam similar to yours, they performed very well. PM me and let me know if you want them.
i would get 5.3 heads You would be around 420ish easy. Check into prc heads too Let me know if ya need help im on the other side of lee's summit in warrensburg
thanks SIC LSX. im about to pull the trigger on one or the other. i am def. leaning towards the 5.3's though. I would love to get some input from one of this sites technical guru's though.... predator z or patrickg?
I would prob get the 5.3's for your setup. I would get PRC's instead of Patriot's IMO. I have heard they flow a little better. Dont know if thats true, but that's what I have been told.
I actually looked into this when I was getting my H/C setup. The patriot heads when fully assembled cost a little more(if I remember correctly) and flowed just a little bit less. You also get more from texas speed when you buy the package deal for the same price as heads only when you buy the patriots.
I have the 59cc ls6 patriot heads and am really happy with them. i do not have dyno numbers, but i have beat a c6 vette from a roll and break the tires loose from a 40 punch with new tires. I am not sure if they are better than the 5.3 heads but they are a definate noticable upgrade from the stock 98 heads. For the money i spent i am really happy.Good luck with the combo you choose.
frito1 I have been using a small shop out in olathe for quite awhile. they are pretty good but turn around time always seems to be slow and price rather steep for what seems like is actually getting done. i think this site is a little picky about throwing shop names around if they aren't a sponsor so ill shoot u a pm.
