Speed Inc. SI5 cam with AFR 205s
I'm going to be buying some AFR 205s for my car soon and I have a few questions?
Current Mods:
SI5 Cam 231/237 .589 .595 112
Patriot "Gold" .650" lift dual springs
Comp 7.400" CM pushrods
SLP oil pump and timing chain
Fast/NW 92/90
Fast 36# injectors (I'm also planning on installing Racetronix fuel pump kit w/hotwire)
1. Can I save some cash and reuse my Patriot Gold springs or should I use the upgraded AFR springs?
2. Will LS7 lifters work well with my set up?
3. Should I buy some Harland Sharp 1.7 rockers or just reuse my stock rockers?
4. Are the 36# injectors and Racetronix fuel system enough to spray a 100-150 wet shot with the H/C?
5. Besides gaskets, is there anything else I should buy?
6. What kind of rwhp/rwtq can I expect from this setup? (The car dynoed 402/375 with the cam and boltons thru a 9")
Current Mods:
Fast/NW 92/90
No track times yet. I will be going to Byron Dragway on Sat. and hopefully come back with some 11 second slips. I was originally going to spray 100-150 shot at it but I have decided to hold off until I get heads.
Depends on how many miles on your springs but personally I would get the AFR springs
Ls7 lifter will be fine
Personally if you were to get rockers I would get the modded stockers by HS
Yep should be enough, thats what I will be running with mine
depends on what you already have...
I dont know but I have a similar setup and im hoping for anything above 450
Current Mods:
Fast/NW 92/90
Current Mods:
Fast/NW 92/90
What a coincidence.
Turns out I have the same cam and I also have brand new AFR 205's (along with a **** load of other parts) in my closet ready to be installed.
My car is an automatic though.
Here's a list of parts I bought for the head swap:
-AFR 205's with upgraded 8019 valve springs (so yes, get the upgrades from AFR)
-LS7 Lifters
-Lucas 42lb injectors
-Cometic head gasket
-Intake gaskets
-Valve cover gaskets
-Tims valve spring tool
-Com camp push rod length tool
-ARP head bolts
I was gonna get Yella Terra rockers but I keep hearing that the stockers should be fine as long they're in good shape.
I'm also planning a 150shot in the future so I can't wait to see how yours does.
Anyways, good luck with the build. It's a big headache researching **** because while some people might wanna help you, many just want you to buy their parts, so be weary....
