get a few questions with MS3 and TSP heads
got a few questions with MS3 and TSP heads
i installed MS3 and stage 2.5 5.3l heads (with necessary upgrades)LT, ORY . my questions when i start the car i get a white smoke from the exhaust and it is quite a potent smell. my other question is the car wont idle worth a damn it has been tuned twice by Texas Speed and it wont idle right ive checked for vacuum leaks. replaced the PCV valve hose, IAC and it wont drop rpms when i push in the clutch only when i come to a complete stop. any suggestions?
after my dyno, the car ran great. Before I had to drive with two feet to keep the car from stalling at idle. A mail order tune is just enough to get the thing started without hurting anything. As for your smoke issue im not sure. Did you install yourself? We did my install in the garage and never had any kind of smoke issue. How long has it been smoking?
LS1Tech Premium Sponsor
Not all 5.3l heads require the graphite gasket, it depends on the heads. Did you check the rocker arm bolts & seal them? Also how's your breathing configured?
From a tune perspective it should be pretty easy to get the tuning lined out. Is it tripping any codes? WHat IAC counts are you seeing? Any ideas on fuel trims & the condition of the o2s?>
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
i have yet to pull anything apart again but i followed ls1howto.com for the install. i thought on the rocker arms u just torqued them down. i a slp lid and everything else is stock. i dont get any codes and i dont have the stuff to monitor any of the conditions
what type of sealant are we talking about here?that is why i have a scanmaster and hp tuners so i can monitor but you can always buy a scanner or borrow one from a buddy,a regular obd2 diagnostic scanner sometimes will allow you to see live data.
