is the melling m295 and 10295 oil pump the same?
the only oil problems LSx motors are prone to is when the pump actually fails correct? I have not come across any threads where volume was an issue so the standard volume should be just fine shouldn't it? I do understand the why not go bigger theory but I also believe in the if it aint broke dont fix it theory.
thanks for any input guys and also thanks for the already provided input.
Yeah, you need to grind the cover in a bunch of places, and a little off the front of the pump, but it work. And also changing the front bolts to button heads really helps. I have a bunch of them if anyone needs some.
the only oil problems LSx motors are prone to is when the pump actually fails correct? I have not come across any threads where volume was an issue so the standard volume should be just fine shouldn't it? I do understand the "why not go bigger" theory but I also believe in the "if it aint broke dont fix it" theory.
Quote from Melling tech support
The M295 and 10295 are NOT the same.
The 10295 is their ‘high performance’ model, it is anodized, has a stronger rotor set and is more durable
the M295 is a stock replacement.
Wayback machine just sputtered and quit....
The following users liked this post:
LilJayV10 (10-18-2020)
G Atsma (10-27-2020)
