water in valve covers / pcv!!!!
Ok, here is the short of it. Was losing water and couldnt figure out where it was going. Crankcase was just oil no water, no leaks couldnt figure it out. Finally found it in the valve covers and the pcv. Was told blown head gasket or even worse cracked block/heads/warped heads etc. Tore into the engine and decided to check the torque on the heads (arp head bolts) and the very first one was only 22ft/lbs now for the big question...can i just torque everything down or should i go ahead and replace the head gaskets????
If it were me I would be pulling heads. You're already started with the tare down. I'd want to know what my head gasket looked like before I have a hydrolocked engine, and with the money you have spent on that engine, removing the heads would be the least of my worries.
I would get a shop vac and suck out all the coolant roll the piston to the bottom of its hole and get something like this product. you spray on a "film" coat then a "developer" and if the sleave is cracked it will show up as red. You should be able to spray in to coolant jacket to see the damage too.
http://www.vobaker.com/ndt/spotkit.htm
Sorry to see that kind of problem. good luck.
and found out on friday when i went to change the oil and found the gunk in the valve cover but nothing in the crankcase but oil
My thoughts would be that "gunk" is something that was used in the assembly process. If that was something water related on your valve covers, that would have showed up in the crankcase as well.
i dnt know what to tell ya..... except the motor was torqued to specs. ive built several ls1 and never had a problem....you get my car and it seems you have nothing but problems
If its a true 5.7 "LS1" aluminum Block then it can be welded up and re-sleeved. If its an Iron 6.0 block Then It's most likely Junk at this point.
Location: Chitown-Jax NC-Jax FL-Honolulu-OKC, OK-NOW New Orleans Area
damn bro .. get me some more pix after it is vac. out. try to wipe it all down to get a better look. I am trying to find a block now. Looks like I am going to be coming up in OCT to help build a motor.
This is true. I see the same thing if I go on short trips and turn the car off, that residue will be on my breather cap. If you aren't loosing any coolant then I'd say you are safe. That crack could be something though. If it isn't anything now, it may be something later.
