Ticking noise that only comes when car is hot?
Old 09-05-2003, 01:36 AM
mhoward's Avatar
Default Ticking noise that only comes when car is hot?
I don't know what is doing it, but after a fast drive when the car is totally hot I get a ticking noise coming from the driver's side. It's never done it other than about 3 times right after a wide open throttle run. Any ideas?
Old 09-05-2003, 03:29 PM
robertbartsch's Avatar
Default Re: Ticking noise that only comes when car is hot?
..bent pushrod, broken valve spring, bad lifter, bad rocker arm?
(b) all of the above
Old 09-05-2003, 03:43 PM
XFACTOR's Avatar
agreed one of the above
Old 09-05-2003, 06:11 PM
LS1swap's Avatar
Of the above only the lifter could be intermittent when hot... The others would do it all the time. One not listed is warped valve. They tend to stick more when hot than cold. Take a ½ rubber hose and hold it to the head with the other end to your ear. You will probably be able to single out the piston in question. Not a 100% but may give you a good idea where to look.
