Need cam advice & hp gain info for a streetable LS6 motor...
Old 09-10-2008, 12:04 AM
nighthawk355x's Avatar
Question Need cam advice & hp gain info for a streetable LS6 motor...
I've got a 98 WS6 with a 2003 LS6 longblock straight from a Z06. Car has full bolt-ons now and runs great, I can drive it anywhere and still get semi-decent gas mileage. The problem...needs some bigger *****.
It's at a barely tuned 385rwhp/381rwtq and I think it has more in it. I think it could almost push the 400rwhp/tq mark with a good tune, but I'm thinking a cam and tune.
So here's what I'd like...
a mild but streetable cam that'll add as much power as possible without making it sound and run like an animal. I want it so people barely notice there's a cam in it. I also want it to be something that'd go good with a blower if I ever decide to go that route. If I could somehow pull about 450N/A rwhp/tq out of it at the same time that's be ideal!!
If anyone has something similar can you post up a vid so I can hear it. And also, let me know what numbers you make with your setup.
Thanks everybody!!
Old 09-10-2008, 12:32 AM
FlashLCD33's Avatar
You need to say more than "I want 450rwhp"
What trans? Gears? Converter (if auto)?
You need a better tuner also it would seem. One of my friends made 405rwhp on a stock longblock ls6 with headers, ory, fast90/nw90 right after it rained in 80+ heat. 6spd through a 9". There are people on here in better altitudes with better dyno conditions that made that much or more with an auto even.
Old 09-10-2008, 12:40 AM
Yea I know the tune needs to be redone.
As for drivetrain setup, it's an M6 with a ram powergrip and upgraded slave/master, stock 10 bolt with 3:42's(I know, it's on borrowed time).
Old 09-10-2008, 01:32 AM
F8L_LS1's Avatar
i dont know much about blower cams so for what NA's worth i think you should go with a 228/228 .590/.595 with a 115/6 lsa. (pretty much the same specs as TSP's 228r)
i chose such a high lca since you want it to be a sleeper.
a 228 cam shouldnt kill your drivability too much either.
i dont know too much about cams but i think that would compliment your other mods since you have a fast 90/nw90 and pacesetters LT's.
predator-z can spec you a cam much better than i can. or most of the sponsers on here can do the same.
Old 09-10-2008, 10:30 AM
teke184's Avatar
224 cam would do nicely.
you could look into something like the cheaTR perhaps...but i'm not sure how much you'd gain.
Old 09-10-2008, 06:52 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Both the 224R or the 228R camshaft would work really well. Our dyno testing showed 70hp gains from the 224R over a stock LS1 camshaft. It wouldn't be as much when replacing a LS6 cam, but it would still do very well! With either the 224R or the 228R you could run the Comp 26918 spring to save a little bit of cash!
That package is currently on sale with your choice of camshaft!
http://www.texas-speed.com/shop/item...d=174&catid=49
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
