PRC 215cc Specs, Dyno Info & Videos INSIDE!!
After nearly 2 years of developing on the PRC cylinder head casting, we're finally almost there! Here's some early data from the 215cc runner. We're also working on a 205cc, 225cc, and 237cc runner for the guys looking for different port sizes!
The 215 Features:
2.04/1.60" Stainless Valves
215cc Intake Runner
Bronze Guides
Thick Deck For Power Adder Applications
Raised Valve Cover Rail For Increased Rocker Clearances
Rocker Arm Provisions For Stock or Aftermarket Rockers
6 Bolt Configuration STANDARD!
61.5cc Chambers Standard!
*Chambers Can Be Milled To 59cc & Maintain Stock p/v!
**Allows the use of MS4 size camshafts without the need for valve reliefs!Pics:
Dyno Pulls:
http://www.precisionracecomponents.com/prc215dyno.wmv
The 215 Features:
215cc Intake Runner
Bronze Guides
Dyno Pulls:
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
LS1 Tech Administrator
Looks very promising. Any pricing or availability info?
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
LS1Tech Premium Sponsor
We're not quite ready to release full specs or pricing yet guys. Stay tuned though!!!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Teaser!
__________________
__________________
Agreed.
__________________
Well yes, compared to the PRC, Livernois, Patriot, TEA, ETP, etc ported GM castings it will be more expensive! GM is able to make castings less expensive because they pour hundreds of thousands at a time. The aftermarket companies don't pour quite as many, and have better castings with attractive features for racers that make these well worth the money! But no doubt, they are not for everyone.
__________________
Seriously trickflow and AFR have such an amazing name in the aftermarket game that your heads really need to outperform those competitors to have people buy your product over theirs at nearly the same price. I hope you guys do it cause that would just rock!
you guys can argue over the price all you want, but the fact of the matter is that TSP has more than proven themselves capable of casting and CNC'ing an AWSOME cylinder head. just wait, when these hit the market and carve out a niche for themselves, you'll be beating off to all the dyno numbers people post with their stock bottom ends, these heads and 228 cams making more power from idle-5500 than anything else...
then when people start taking advantage of the 6-bolt design and thick deck, well...you can imagine what will happen then
Yeah you are totally right, it's not just the name. Call up any "REAL" aftermarket ls-x shops, and if they aren't trying to sell you a certain brand (cough, cough) the afr and trickflow castings outperform almost every brand and factory ported casting period. Dart and Edlebrock are good "budget" options. Basically no way anyone is going to choose a PRC head over AFR or trickflow at the same price. I would be MORE than happy in the $1300-$1600 range with a single conical spring per pair to give the new PRC casting a chance. Not really sure why PRC/TSP didn't try to develop a ls3/l92/ls7 next gen casting. Seems like the cathedral port aftermarket head sector is loaded with MANY competitive options. Best of luck
