need FULL engine gasket kit...
If building an ENTIRELY new engine (new re-sleeved block), I assume I'm going to need EVERY gasket on the engine.....
Does anyone sell that as a package (give me one of these) so I make sure I don't forget something and how much does it cost (about)?
I don't need any GM bolts (main or head) as I will use ARP studs.
Re: need FULL engine gasket kit...
I was in the same boat and couldn't find anything. I ended up getting the best price at www.paceparts.com I had the parts in 2 days too.
do you have the part number?
I just made a list of all the gaskets I needed and called out. I had to buy them all seperately. Here's a list I just came up with off the top of my head
oil pan
timing cover
crank seal
rear crank seal
rear cover
vally cover
2 water pump
oil pump o ring
crank bolt
head gaskets of some sort also
oil pan
timing cover
crank seal
rear crank seal
rear cover
vally cover
2 water pump
oil pump o ring
crank bolt
yeh, I agree.
I did buy a new timing cover gasket and upon removal from the package discovered it was cracked.
I re-used the old timing gasket and it has not leaked; a testiment to the re-usable design, however.
At this point its still in the planning process but I KNOW I'm going with a 4.125" bore LS6.
I'm still looking into if I should just go with MTI's dry sleeve block or have the guy that did my heads (engine builder) do a wet sleeve (Darton) block.
The stroke is going to either be stock/3.622" (388CI), 4" (427CI), or 4.125" (441CI) depending on what I untimately decide I want to make (hp) and spend.
