ASP pulley wobbling at idle after cam install
Old 09-07-2003, 03:31 PM
TAhawk69's Avatar
Default ASP pulley wobbling at idle after cam install
I just had a TR220 cam installed and the ASP pulley is wobbling pretty bad at idle. It seems to get better as you increase rpm. What can cause this? Is this a pulley issue or install issue? Btw, the car is a 2001 T/A auto.
Thanks,
Marco
Old 09-07-2003, 05:19 PM
AZLS1's Avatar
Default Re: ASP pulley wobbling at idle after cam install
If the pulley didn't wobble before then it is an install issue.
It can cause damage to the belt or cause the belt to come off completely.
Take it back and have the intaller correct the problem.
Old 09-07-2003, 05:35 PM
The Dragon's Avatar
Definitely a bad install. Get that fixed asap. Don't want it messin' with your crank.
Old 09-07-2003, 07:06 PM
v8maro's Avatar
Hey marco, I met you today and saw your red hawk over at Tim's. It looked like it was wobbling pretty bad, but i know tim will make good on his work.
-Steve
Old 09-07-2003, 07:10 PM
Scalpel's Avatar
Fix that ASAP! Do NOT drive it until you fix that. BAD BAD!
