melling 295 pump and double roller who is running one?
Who is running a melling 295 with double roller chain. I had a 296 melling that was going to use but its a pain to use double roller with it and dont feel like grinding and mucking on things.
So figure just go with the melling 295. Also do the 295s have the high and low pressure springs?
I have the 295 with a double roller chain and I had to grind a bit even with the shims that came with the timing chain. There were no extra springs with the pump to change the pressure.
#295 pump should go right on, with minimul grinding around pick tube area. The new style melling oil pumps (there all black in color) have an impression casted into the both pumps in the spot already for added clearance for aftermarket dbl roller t/c setups, but sometimes you have to touch that area up a bit.
