People with TR224 cams or 224 XE-R cams come inside..
Old 09-07-2003, 06:42 PM
Shorty Director
VINCE's Avatar
Default People with TR224 cams or 224 XE-R cams come inside..
I would like to know where your horsepower peaks at? I am trying to help 99 Black figure out why his car peaks at 5900rpm.. I would also like to know how much advance you have built into your cam..
Old 09-07-2003, 07:00 PM
Tally TransAm's Avatar
Default Re: People with TR224 cams or 224 XE-R cams come inside..
my cam is straight up, no advance
Old 09-07-2003, 07:05 PM
Hardtop's Avatar
Vince, my XER peaks between 62-6300 rpm.
Bruce
Old 09-07-2003, 09:10 PM
98TAauto's Avatar
i dont have a clue.. i had the car shifting at 6450 on edit
I woulda thought he would peak at around 6200atleast
every car is different though
Old 09-08-2003, 03:04 AM
jaberwaki's Avatar
whats your total advance set up???
Old 09-08-2003, 11:59 AM
The Bull
DERTY's Avatar
Mine was at about 6300 last year. Straight up on a 114.
Old 09-08-2003, 12:30 PM
Chubby's Avatar
6200-6300 straight up ona 112
Greg
Old 09-08-2003, 04:47 PM
Ed Blown Vert's Avatar
Mine is about 6000. But I am sure it is because I don't have headers yet.
Old 09-08-2003, 04:50 PM
Shorty Director
VINCE's Avatar
I am wondering when 99 Black is going to chime in? This thread is to help him troubleshoot his car peaking at 5900rpm even with him taking 4 degrees of advance out of the cam during install..
Old 09-08-2003, 05:03 PM
muscratmauler's Avatar
6500 ON 112
Old 09-08-2003, 07:40 PM
EVIL's Avatar
mine is at 6200
i guess its pretty close then, i thought something was off about it.
Old 09-08-2003, 07:43 PM
Cal
Cal's Avatar
I believe the headers will have some bearing in where it peaks also.
Old 09-08-2003, 10:27 PM
99 Black Bird T/A's Avatar
Received 1,431 Likes on 991 Posts
Vince, I appreciate the thread! Will have a jpeg of my graphs tomorrow to post in the thread.
Since many cams lose ~1 of LSA when Comp grinds them, my 224 XE-R cam was spec'd as a 113 LSA with 4 degrees advance ground in. The cam doctor showed the cam was ground with 1 degree of retard, giving ~3 actual degress of advance. Due to P to V issues because my heads were cut ~.020 to ~.030 the cam was installed with ~2 degrees advance to keep the P to V safe at .075 clearance on the intake side and ~.100 on the exhaust. Cam was degreed in.
224 XE-R with actual LSA of ~112 installed 2 degrees advanced.
Since heads were recived full of metal shavings because they were not cleaned after being decked, they had to come apart. All spring pressures were tested and in spec. Install heights were checked and confirmed. Valve job was inspected etc to make sure everything set up correctly.
Atap show ~27 degrees timing with .1 to .3 degrees of KR. O2's, Ltrims etc were all where they should be. I don't have a O2 A/F because the dyno wasn't set up to give a print out of the A/F verse rpm. At the first dyno session thru the exhaust was 407rwhp thru the cut out was 408rwhp. At the second dyno 408 thru exhaust and 408 thru cut out. We let the car sit and cool down for 45 minutes, it made on pull at 418rwhp thru cut out Next pull was 413rwhp.
Looks like my 224 XE-R is peaking lower than anyone elses.
Old 09-08-2003, 10:50 PM
Shorty Director
VINCE's Avatar
It is peaking lower than everyone elses..
Old 09-10-2003, 09:31 PM
Shorty Director
VINCE's Avatar
From my experience when you take out the advance built into a cam and go minus 3 to 4 degrees negative your peak horsepower will peak later..
Old 09-10-2003, 11:19 PM
RAMnGO's Avatar
even though i haven't had any tuning or had my rev limiter upped it pulls hard all the way to the rev limiter....my lsa is 112 and i installed mine straight up
Old 09-11-2003, 12:17 AM
KillenSS's Avatar
I got my cam today was wondering where it will peak its is a 224/224 .570/.570 110lsa.
I was hoping it would peak near 6000 rpm. does that sound right?
Old 09-11-2003, 12:30 AM
Bowtieman4life's Avatar
I thought advancing the cam lower the peak hp rpm.
Old 09-11-2003, 12:34 AM
The Dragon's Avatar
Thunder's 224 on a 112 LSA here:
peaks at 6050 rpm straight up.
Old 09-11-2003, 03:02 AM
Mike K.'s Avatar
Vince mine peaks around 5900 as well and it was installed straight up with 4 degrees of advance built in. This was with the SLP headers on also.
