Where can I buy a MTI cam?
LS1Tech Premium Sponsor
You can always give us a call with the specs you're hunting and we can get Comp to grind something up. Unless it was a proprietary lobe they used (often not the case), we can usually get it done for you! Let us know if we can help!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
mti LIDS
I can get a 233/239 cut for you and shipped for $379. or you can choose any of these lobes Shipped for $355
https://ls1tech.com/forums/showthrea...hlight=233/239
__________________
Let us know if you need a cam. We will BEAT ANY PRICE ON CAMS!
What we are selling are Comp camshafts. They are by far the most popular camshaft profiles on the market. We have dyno tested and know EXACTLY what kind of numbers each camshaft should put down. Anyone can pick numbers off a lobe sheet and hope they work. We have actually been to the engine dyno testing anywhere from 10-25 cams at a time to ensure what we put out on the market will do exactly what they say it does. That also gives us the ability to spec a custom cam for you if you would like. There is no additional charge for custom grinds either! Let us know if you have any questions or need to place an order!
Jon Reynolds
Texas Speed & Performance
Jon Reynolds
