Whats A Good Crank Pully
HI i HAVE A 2002 LS6 THAT i AM INSTALLING IN A 69 CAMARO, WHAT IS A GOOD CRANK PULLY,
STOCK
A A/M ONE
UNDER DRIVE
THE CAR IS A 6 SPEED CAM HEADS INTAKE
THANKS FOR THE HELP!!
STOCK
A A/M ONE
UNDER DRIVE
I have an SLP unit and the quality is excellent. Whatever you get, go ahead and get the ARP bolt and torque to ARP specs, then you can forget about it. The SLP unit does not require an aftermarket belt tensioner, due to the pulley walls being deep. But it is a bit heavier than some others.
The Powerbond is a very nice pulley like mentioned above. (SLP is reboxed Powerbond) They are SFI approved and already keyed should you want to key the crank. They will tyipcally pick you up about 8 RWHP or so. Let me know if you need one. We have them in stock and ready to ship immediately!
Jon Reynolds
Texas Speed & Performance
Jon Reynolds
Powerbond and SLP are the same pulley and are very good pulleys . If you get one and are picky about appearance, I would paint it or have it powdercoated because they will be covered with surface rust before you know it .
If you are looking for more of an actual dampener, I would go ATI hands down. However, if this is a street/strip car not spending most of its life at 7000 + RPM, there are probably better places to spend your money than on a $500 pulley. The Powerbond makes more sense. That being said, if you are looking for the best on the market, ATI is they way to go IMO.
Jon
Texas Speed & Perf.
Jon
Texas Speed & Perf.
I dont understand why everyone says the PowerBond and the SLP pullies are the same, Has anyone ever sat the 2 next to eachother. I have an SLP on my car and one of my friends has a PowerBond. The Major differece is that the SLP has tall side walls to keep from throwing belts. The PowerBond does not have the same side walls as the SLP. In my book, that makes them different.
