Need to know ls1 arp rocker stud part numbers asap
Old 09-18-2008, 01:50 PM
MY99TAWS6's Avatar
Default Need to know ls1 arp rocker stud part numbers asap
Am making an order asap and need to know the arp rocker stud part numbers for ls1 . I assume they are 3/8 inch? Do I need the more expensive pro ones ,engine is only going to be taken to 7000 rpm max.
The more expensive ones are double the price and will pay it if you guys really think they are necessary.
Old 09-18-2008, 02:10 PM
MY99TAWS6's Avatar
Hmm looks like need to buy rocker arm nuts as well.Anyone got these and what part numbers did you use..they list two rocker arm studs.
Old 09-19-2008, 09:55 PM
JPH
JPH's Avatar
EDELBROCK #8597 (2), these are ARP rocker arm bolts for stock gm LS1 rocker arms.
Old 09-19-2008, 11:37 PM
MY99TAWS6's Avatar
So do these work with my yella terra rockers ? Think they use stock nuts?
Woudln't mind a bit better rocker studs..so stock is 3/8 inch?
Old 09-20-2008, 04:35 PM
JPH
JPH's Avatar
Dunno on that? YTs should have came with new hardware? 8mm stuff. Are your rockers adjustable?
Old 09-20-2008, 05:16 PM
MY99TAWS6's Avatar
Non adjustable 1.8s. Should take a look in the box but think they just use stock rocker nuts.
Old 09-20-2008, 06:41 PM
KCS
Moderator
KCS's Avatar
Yella Terra's (and all stock LSx engines for that matter) use a bolt, not a stud. The LSx engine is metric, so its not a 3/8" bolt, its an M8. I think 40-45mm in length should be fine, in the "course" thread I think.
Usually YT supplies just a standard Grade 8 allen head bolt that you can pick up at any old hardware store.
Quick Reply: Need to know ls1 arp rocker stud part numbers asap
