Best way to repair pistons? fly cut? (in car)
Old 09-22-2008, 07:11 AM
rufretic's Avatar
Default Best way to repair pistons? fly cut? (in car)
Well I put some notches in my brand new pistons from ptv issues. How can I fix this problem? I've heard the marks I've made can cause hot spots/problems. Can I leave them? If not, can I just smooth out the marks or do I need to fly cut? The pistons came with valve reliefs but obviously not where I needed them. Heres the worst one:
Old 09-22-2008, 07:55 AM
Dracer173's Avatar
Default fly cut
just fly cut the pistons, sand the cut area after cutting to remove sharp edges. Isky cams sells the tools you won't have any hot spots.
Old 09-22-2008, 12:59 PM
Chevy406's Avatar
I just ordered my fly cutters from lindetools this morning. The advantage I see with the Linde cutters is that they will not damage the valve seat in your head. Whereas some of the other cutters require a junk head that has had the seats removed.
Old 09-29-2008, 03:26 PM
rufretic's Avatar
Where did you get them, website? I'm having a hard time finding them.
Thanks.
Old 10-01-2008, 12:20 AM
Turbo.TransAM's Avatar
x2 with the flycut
did you bend valves?
Old 10-01-2008, 09:59 PM
rufretic's Avatar
Originally Posted by Turbo.TransAM
x2 with the flycut
Not sure but I'm changing heads anyway.
Old 10-01-2008, 10:11 PM
JPH
JPH's Avatar
You did that, or was it machined like that already? If not, Yes you can flycut the pistons in the car and not upset the balance of anything. www.iskycams.com sells the tool to do it.
Old 10-01-2008, 10:33 PM
rufretic's Avatar
I did the little one in the center and on the right. The larger valve reliefs were machined like that from the factory. For some reason the reliefs were not where my valves made contact.
Old 10-01-2008, 10:37 PM
JPH
JPH's Avatar
What heads are on this motor, and what pistons are these? Wiesco maybe.
Old 10-02-2008, 06:54 AM
rufretic's Avatar
Stock 317s and Diamond -28cc boost pistons.
Old 10-02-2008, 08:05 PM
JPH
JPH's Avatar
Hmm... Ok. Well what was you PTV clearance when you assembled this engine to begin with?
Old 10-02-2008, 09:53 PM
ChiTownHustler's Avatar
Yeah and what kind of camshaft was used
Quick Reply: Best way to repair pistons? fly cut? (in car)
