Oil on plugs... driver side only
11Second Club
Hey guys,
I have been battling a slight misfire problem that is more of an annoyance than anything else. In doing so, I pulled plugs one through six (I'm too lazy to pull 7 and 8), and I saw that all three driver side plugs had oil on them while the passenger side looked clean.
The valve cover gasket is good, and there's no oil on the head itself. The PCV line going to the intake manifold does look pretty bad with tons of oil residue on the outside, and when I pulled it off to look at it, I definitely got a nice coat of fresh oil on my hand. However, I don't see how that could be the problem when I'm getting oil on only one side. The throttlebody didn't have any oil in it, but I didn't get a good look at the intake manifold.
Any ideas? Could this be a bad head gasket? I mean, I don't see how it could be valve stem seals, rings, etc. I mean, what are the chances that three cylinders on the driver side would have a problem and three on the passenger side wouldn't?!
Are you sure it's oil and not fuel? A bad 02 sensor could try to dump more fuel, which would cause a misfire and wet plugs. Been there, done that!
One side will usually show rich, and the other side will look a tad lean. PCM trying to compensate is my guess.
11Second Club
It occurs to me that I have a HUGE exhaust leak between the driver-side header and the Y-pipe. It's really epic-sounding. I wonder if that could be the cause of this.
11Second Club
The leak is after the O2 because the O2 is in the collector, and the leak is between the collector and the pipe... however, I've read several times before that the pulsing of the exhaust can actually allow air to get sucked in through a leak and actually pulled upstream to an O2 if it's in close proximity.
Do you guys agree that this is a possibility? Again, I'll have good pics up tonight.
Not sure about the air getting sucked upstream, but it seems unlikely. You should fix that first and see if it does anything. If not, at least you won't hear the ticking any more
I'm not the best at reading plugs, but that looks a lot like fuel to me. Usually oil will leave more deposits because it doesn't burn off as easy.
11Second Club
I pulled #1 again today just to look at it in the sunlight, and it looked and smelled like oil. I'd really prefer to believe that it's fuel because the solution is more likely to be simple. Look at the picture of #5? That looks awful dark and thick to be fuel. Plus, wouldn't the fuel evaporate in short order after pulling the plug?
Anyone have any opinions about the plugs looking rich or lean?
11Second Club
I spoke with my dad about this a bit, and he suggested that it could be bad valve stem seals. My first thought was that it couldn't be all of them on one side... However, I have had to change a few valves on that side, and I didn't change the seals at that time.
I noticed today that my car smoked on a cold start. There was no other oil smoke the rest of the day. That definitely looks like valve stem seals to me. My question now is this... could oil leak through the seal, down the stem, out from the seat, and then run along the top of the combustion chamber (rather than dripping down onto the piston) and then crawl up the threads of the plug? It sounds plausible to me, but has anyone ever seen oil on plugs due to valve stem seals?
