Blocked PCM? Cant tune
Old 09-25-2008, 05:06 PM
txturbogs's Avatar
Default Blocked PCM? Cant tune
I was told by my mechanic that the PCM is locked, so it cannot be tuned past minor things like a few degrees of timing, etc.
I've spent now a considerable ammount of money on parts, labor, etc, and its adding up. Is there a way around this?
Old 09-25-2008, 06:10 PM
99blancoSS's Avatar
What year car? Is the pcm stock?
Old 09-25-2008, 06:18 PM
txturbogs's Avatar
it's an 02 PCM out of a camaro put into an RX7
Old 09-25-2008, 08:49 PM
99blancoSS's Avatar
Sometimes a handheld tuner will *lock* it but I think all you need is a techII to over ride it. The tuning section can tell you quick enough, the thread should be moved or start one in there yourself, you'll get a quicker resolution.
