all i can say is changing valve springs sucks
Old 09-09-2003, 03:34 PM
pdd
pdd's Avatar
Default all i can say is changing valve springs sucks
i hate changin the valve springs. worst part of changing the cam and springs if u ask me. even worse than yankin out the steerin rack
Old 09-09-2003, 03:36 PM
gomer's Avatar
Default Re: all i can say is...
Which spring tool are you using?
Old 09-09-2003, 03:42 PM
v8maro's Avatar
Heh, a shop around here quoted me $175!!! for dual spring swap, i heard that and i was like :o
-Steve
Old 09-09-2003, 03:44 PM
jrp
SN95 Director
jrp's Avatar
-Steve
just for the spring swap , im going with rev duals on my but am having a board member do my whole cam and valvetrain for 400.
Old 09-09-2003, 04:39 PM
SSactionLs1's Avatar
Default Re: all i can say is... *DELETED*
Post deleted by jmX
Old 09-09-2003, 06:44 PM
DaleMX's Avatar
I thought that dual springs required machining. Or the rockers might need clearance cut on them.
Old 09-09-2003, 09:32 PM
BIG PD's Avatar
dual springs do need machining.
Old 09-09-2003, 10:11 PM
Restricted User
CAT3's Avatar
The revs dont need cutting of the heads, and a new crane one doesnt either. As well, either of those shouldnt need to the rockers clearanced as they should set the same as the stockers.
Old 09-09-2003, 10:39 PM
jrp
SN95 Director
jrp's Avatar
:yup: the REV duals need no machining (sp).
Old 09-10-2003, 12:48 AM
pdd
pdd's Avatar
im using the moore tool and the napa tool cut like on jmx's site. hate them both
Old 09-10-2003, 02:34 AM
jmX
jmX's Avatar
Please do not create topics with titles that do not hint as to what is inside. "All I can say is..." is not a valid topic for a thread in this forum. I've changed it for you this time.
Thanks!
Old 09-10-2003, 08:43 AM
Larry's Avatar
It's not too bad if you have the right tool. http://www.mustangmods.com/data/440/valvespringtool.jpg
I am having several of these made and offering it for $25.00
More details here:
https://ls1tech.com/threads/showflat...=7&fpart=1
Old 09-10-2003, 09:00 AM
eallanboggs's Avatar
Default Re: all i can say is changing valve springs sucks
You have to take your time. This in NOT the kind of work that is done "assembly line" style. If you use compressed air you can do both vales on each cylinder at the same time. Plus if you have two spring compressor tools you can use one tool to compress the new spring and have it ready to go in BEFORE you remove the old spring with the second spring tool. You have to purchase a spare spring retainer to take advantage of this time saving method. Just using the compressd air trick and two spring compressor tools saves a lot of time, but it sounds like saving time wasn'[t your concern. Try the OEM spring compressor tool that Auto Zone loans out. It doesn't cost you anything, but a deposit which they return to you when you bring back the tool. It works good. You just have to try and get each spring compressed the same amount every time. If the sping is compressed too much the locks don't want to stay in place and if it isn't compressed enough the locks won't drop into the retainer. The right tool, as in any job is key to success.
Old 09-10-2003, 09:45 AM
Ramair346's Avatar
Yeah, the TDC method is the way to go in my opinion. 2 cylinders ready to go. You could also have another person working on the other side should you have 2 compressors. I've managed to get the Napa overhead tool to work on all 8 cylinders on an F-body. $33 and it works great on single springs. Duals are like playing with a loaded gun though. Plus, it eliminates any risk of cross-threading the rocker bold when using the other tools.
Old 09-10-2003, 11:31 AM
KGSloan's Avatar
i love the cut down napa tool
i did my entire spring swap in a couple of hours with it.
Old 09-10-2003, 12:29 PM
pdd
pdd's Avatar
well i finally finished them. i ended up using the moore tool for the whole install. o well. sorry about the topic starter jmx. me fix it next time
