SI4 vs 228R
Old 09-28-2008, 01:25 AM
jetlag's Avatar
Default SI4 vs 228R
So...what is the different between Speed Inc.'s SI4 and Texas-Speed's 228R?(other than the LSA)
SI4 228/228 .588/.588 113
228R 228/228 .588/.588 112 or 114
Old 09-28-2008, 05:36 PM
WS6Jim's Avatar
The name the packaging and the place which you buy them from.
Old 09-28-2008, 05:50 PM
SOMbitch's Avatar
I would GUESS the lobes. The 228r is on XE-R/XE-R Comp lobes. Not sure on the SI cam.
Old 09-29-2008, 09:41 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
The current 228r is definately XER lobes. If you'd like to checkout some engine dyno data from our cam swap testing give us a call. We can fax you over tons of dyno results!!
http://www.texas-speed.com/shop/item...d=167&catid=44
Baseline
http://www.precisionracecomponents.com/stock.jpg
228R
http://www.precisionracecomponents.com/228r.jpg
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 06-16-2012, 10:16 PM
14k
14k's Avatar
Bumping up an old *** thread. Since it was never answered.
Old 06-17-2012, 11:05 PM
I8UR4RD's Avatar
seems like it was answered to me. id check to see what lobes the SI4 has, and see if they are going to provide the results your looking for in the cam. I do not want to be biased, but I can say my 228r @ 114 netted me 393rwhp with stock heads through an auto
Old 06-18-2012, 04:43 PM
PREDATOR-Z's Avatar
From what i can gather they are the same cam on Compcam XER lobes just different LSAs
Old 06-19-2012, 09:00 PM
VincesSS's Avatar
Agreed with above.. can't imagine 2 different lobe designs having identical lifts at the same duration.
Old 12-31-2012, 02:28 AM
JoshuaGrooms83's Avatar
so what does the 1 degree in LSA really change?
Old 12-31-2012, 02:53 PM
Remnant-of-VII's Avatar
The idle characteristics and where the power band starts and ends on that cam.
Quick Reply: SI4 vs 228R
