is a oil needed
It is usually recommended when you do a cam swap because you are already pulling the front of the motor apart so its a good time to do it. A lot of times people like to go with a Ported pump with a stiffer spring which helps raise the oil pressure up. Some of the 98-00 pumps are pretty weak and after some miles start only making 20-25 psi of oil pressure at idle. You can go with an SLP pump or a melling or companies like Texas speed have them too that are basically LS6 pumps that are ported with the stiffer spring inside.
im think of running ported ls6 heads, i want to freshen up the motor it has 82000 miles on it and i wanted to change out the rings and bearings. i have also thought about changing out the rods and pistons but that like $1200. so i dont know if it is worth the money seeing is that im never going to spray it. and i heared the bottom end is go to 400-500hp.
Well if it was my car and the oil pressure is good and no knocking sounds and it has good compression, I would do the recomendations in my last post and go have some fun with it . I would wait for rings and pistons and all the rest until it is really needed . Meaning when you are ready to do a complete rebuild with forged internals .
