What heads and cam?
I have a comp. 581/588 224/230. With fast 90/90 Trickflow 215cc heads stock 26lbs injectors stock fuel pump qtp headers and magnaflow cat back 6speed 465hp 431tq to wheels. New pump and injectors prob close to 480hp
yea it did the tune was backed off to the 465 the injector are at about 92% duty. i fried the stock pump its has a 255 walbro in it now it also has stock 36lbs gto injectors. it broke a rocker arm on dyno yesterday. it not tuned for new pump and injectors yet
with stock 3.42 in 6th gear i rev bought 1600 rpm about 23mpg highway i put about 250-300 miles a week. i drive late spring all summer and early fall no winters some rain but not much
LS1Tech Premium Sponsor
Tell us about your car & the goals, it's hard to say what combo would do best without a little more info.
We have tons of engine dyno data from several different cam/head combinations. If' you get some time give us a call & we can fax you over some of the dyno data from our testing.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
