Rocker change with 02 LS6 Cam........
I'm considering changing the rockers from stock. How far can I safely go to squeeze a little more out of this "Baby Cam"?
I am currently also waiting for my Pacesetter LT's w/ORY from TSP. Right now I'm running a 2 1/2 Bassani ORY with stock manifolds and hope to get 2 tenths and 2 MPH from the LT's and bigger ORY mainly due to the cam.
Any info or input would be
TIA,
Kurt
TIA,
Kurt
Re: Rocker change with 02 LS6 Cam........
I am curious about this alos. I too have this cam, and was thinking about changing to a set of different rockers. Which ones should I go with?
1.8's will net you .600 lift on an 02 LS6 cam. big plus IMO i'd love to do something like this on a moderately stock car.. ;D
Any guess what kind of gain could be expected?
Thanks
actually, the stock lift on the '02 LS6 cam is .551/.547, so with 1.8 rockers, it would be: .583/.579, and with 1.85's it would be: .600/.595 ... i would use AT LEAST a comp 918 spring... i would get 1.8 rockers that were full roller, not the 1.85 SLP's which r not full roller...
Thanks for the replys. Looking at Thunder Racing, they show the CC 1.8's for $699. The springs would be every bit of $150. Ouch...that stops the idea in it's tracks. I was hoping to lean on the cam a little, but for that kind of money I would be better off swaping cams.
Thanks again.
Thanks again.
