Check my Compression Calculation.
Old 09-29-2008, 11:10 AM
2 SSlow's Avatar
Default Check my Compression Calculation.
I'm at work now and don't remember which calculator I used, but last night I used compression calculator that had the LS1 spec already in it: the results came back at 9:1. It seemed a little low so I just wanted to see if someone could check my results. This will be for a boosted application so it's not all bad if that's correct...it's surprising low to me.
3.905 bore
3.622 stroke (stock)
-4cc forged Probe pistons
72cc 317 6.0 liter heads
.055 MLS head gasket
Let me know if you come up with the same thing. Thanks!
Old 09-29-2008, 11:19 AM
Black98Z28's Avatar
On the c5frc.com calculator I came up with 9:1
Using another calculator I came up with 9.054:1 SCR
Old 09-29-2008, 12:18 PM
mterveen's Avatar
~9.29:1 static. would need cam specs for dynamic.
Old 09-29-2008, 12:29 PM
5.3LJimmy's Avatar
I get 9.30:1 SCR.
Old 09-29-2008, 01:20 PM
2 SSlow's Avatar
Cam is a TSP 233/239 .598/.605 113lsa. I have no idea where the cam card is to get the other info...
Old 09-29-2008, 03:09 PM
mterveen's Avatar
would need intake duration @ .006 or intake valve closing degrees for the dynamic although i wouldn't get too hung up on the dynamic ratio.
Old 09-29-2008, 03:50 PM
That's what she said...
TheBlurLS1's Avatar
http://www.csgnetwork.com/compcalc.html
I like that one.......
Old 11-12-2008, 09:16 PM
ssinister550's Avatar
What is your deck height (.xxx inches in or out of the hole?) Assuming it is excatly 0, using the actual formula for compression ratio, it would be 9.1912:1, or rounded off, 9.2:1
