Are titanium retainers necessary in my application??
Old 10-01-2008, 07:49 AM
Raise's Avatar
Default Are titanium retainers necessary in my application??
So I'm going with a TR224/112 cam for my 02 WS6. I won't be visiting the track much...it is strictly a street car that I like to have fun with. I spoke with Shane at Thunder Racing yesterday and we concluded that I would be ok running a Comp 918 or PAC 1518 beehive spring because of the low lift on the cam. I don't want to get into a single vs. dual valve spring debate, but I have read about several incidents of 918s breaking. I know Comp had a bad batch of 918s before, but I believe there have also been several reported incidents of the new revised 918s breaking. I would like to think that the failure of the revised 918s is due to improper setup, too high of a lift on the cam, or simply spinning the motor too high. Shane also said a titanium retainer would not be necessary unless I would be spinning the motor super high. I will probably be shifting at or around 6200-6400 rpms. So we decided I would be ok with the stock retainers and locks. Any advice or suggestions on my valve spring and retainer choice??
Old 10-01-2008, 08:40 AM
Yeahdoug's Avatar
1518 is a better spring over the 918 because of the nitriding and better material.
But to answer your question on the retainer, I don't feel the Ti. is worth the extra money. The weight difference is tiny.
Old 10-01-2008, 08:49 AM
JPH
JPH's Avatar
Ti retainer is like 4 grams lighter then stock and you pay $130 for them. Save your money and buy an oil pump instead.
Old 10-01-2008, 09:18 AM
Raise's Avatar
I have an 02=I have an LS6 oil pump
Old 10-01-2008, 09:19 AM
Raise's Avatar
Ok, so Ive decided to run the stock retainers. Now I just need to decide on a valve spring.
Old 10-01-2008, 09:23 AM
magic's Avatar
Sorry to hi-jack your thread...maybe I can get an answer on here since we are discussing valves springs....
For instance a dual spring...does the spring seat/pad on the cylinder head need to be machined to accept a dual valve spring or are there sets that fit in the stock location?
I'll be doing a stock head LQ4 6.0 build using the stock heads (budget build/swap) and a "mild" cam like a TR224, and wondering what springs to go with as well.....
Thanks!
Old 10-01-2008, 10:58 AM
Raise's Avatar
Thanks!
A dual spring will fit on the factory seat with no problem. As far as installed ride height, it depends on the spring pressure. Some applications will require you to shim the spring (placing a shim/spacer between the spring and the seat) to "pre-compress" the spring. This will actually compress the spring more than one installed at stock ride height. Plenty of people run singles and duals on the bare seat with small and big cams, while some like to shim for a proper match. If youre going with a TR224, give Thunder a call and talk to Geoff or Shane. They both know their stuff and they will set you up properly.
Old 10-01-2008, 12:28 PM
AU N EGL's Avatar
isnt the idea of the Ti retainer to increase strength, decrease wt so the engine can spin above 6000 rpms?
Old 10-01-2008, 01:41 PM
Raise's Avatar
6000 rpms is debatable. They do increase strength and decrease weight, but the extent to which they do, as well as the $ to gain benefit, is the debate.
Old 10-02-2008, 06:11 AM
Yeahdoug's Avatar
A steel retainer will wear a lot less than a TI. retainer and last much longer.
Old 10-02-2008, 08:15 AM
Raise's Avatar
Is this true?
Old 10-02-2008, 08:30 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Ive talked with Vengence Racing, Predetor-Z and Patrick G. All very knowledgable people. I run my cam VRx4 228/230 @ 112, the lift is slightly under .600 and I run a newer comp 918 spring w/ no issues and spin regularly above 6k. I used my stock 36k mile steel/factory retainers.
The point was if you were running a dual spring like a patriot or a comp 987, you have a LARGE retainer, the beehive's retainer is much smaller to begin with so the we less grams you have isnt worth the cost and your not going to see the difference. You will need rod bolts well before that.
As for Ti, its as strong if not stronger and lighter then steel, but MORE brittled and prone to wear.
Old 10-02-2008, 09:03 AM
99ssleeper's Avatar
you wont have a problem using the stock retainers and spinning it to 6200. ive always used titanium retainers because they weigh almost nothing and i was able to find new comps for $75, so why not.
Old 10-02-2008, 09:10 AM
99_SS_LS1's Avatar
I went with the 1518's on a .609 lift. I've heard nothing but good about these springs, and am glad I exchanged my revised 918's for them.
Old 10-02-2008, 09:18 AM
Raise's Avatar
Im thinking of running the PAC 1218. They are good to .600 lift and my cam is well under that. Plus I have searched and searched and can't find a single incident of a PAC breaking.
Old 10-02-2008, 10:23 AM
thunderstruck507's Avatar
the PAC are the old comp spings IIRC
they're what I ended up with too though
Old 10-02-2008, 12:34 PM
Raise's Avatar
Yeah but Comp was good until they switched from PAC. Thats when their breaking issues started
Old 10-02-2008, 01:27 PM
Goldfinger911's Avatar
What about the LSx Patriot Gold kit? Comes with everything including double springs, seals, bases, Ti retainers, and oversized keepers. You can find it for $240-$250 usually.
Old 10-02-2008, 02:40 PM
Raise's Avatar
Cuz that is overkill for a small lift cam like mine.
Old 10-02-2008, 04:46 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
I like single, beehive springs because of the better harmonics that they afford and lower overall weight. The problems with the 918s started when Comp left PAC and had them made elsewhere. I would go with the higher lift PAC's because if you decide to go bigger lift you could without having to change springs.
As for the Ti retainers, every gram counts in my book when it comes to valvetrain stability. It's like pushrods, could you reuse stock ones, yeah, but for $100 I'd rather have a hardened steel pushrod.
Quick Reply: Are titanium retainers necessary in my application??
