couple flycutting questions
I currently have afr 205's with tsp's old lunati grind 231/237 cam. Im thinking i want a bit bigger cam in my ride and was wondering can i use my old 241 heads as my guides for flycutting? just want to make sure the valves of both heads come down in the same spot in relation to the piston. i know, probably a dumb question but iv been wondering.. thanks
I think they should work. I'm pretty sure AFR heads have stock valve angles. I know that TFS and ETP heads would not work because of there altered valve angles. In not 100% sure tho.
But that set up should clear anyways. Allngnc5 has AFR205's, G5X3, and .040 gaskets I believe and he has not flycut.
Use your old #241 heads to flycut, thats what I do. The AFRs have the same valve spacing/centerline and angle as a #241 head. If your AFR head has been milled, and you are using a .040 gasket I'm confident that you will have to flycut atleast .040+ to be safe. (intake side only)
